APDK66
Oct 03, 2015Aspirant
Can't get GS110TP to work as simple as GS105E
For my work I have to check services going over utp links in different vlans. I used a GS105E with its mirror function. I can connect the GS105E without any vlan configuration and all traffic of doze...
- Oct 11, 2015
So I understand I can't use this switch for what I want. I need to check uplinks containing 250+ vlans.
Besides the different configuration effort each time it has a limit of 64 vlans.
I have to look for another solution.
DaneA
Oct 06, 2015NETGEAR Employee Retired
Hi APDK66,
APDK66 wrote:
The trunk carries vlan 4,6 and 7 for different services.
Kindly set ports 1 and 2 as tagged (T) ports. What is the behavior and the LED color of ports 1 and 2?
You may use other ports of the GS110TP as trunk ports to isolate the problem. Just make sure to set it as tagged (T) ports.
DaneA
NETGEAR Community Team
APDK66
Oct 06, 2015Aspirant
I did set the ports to trunk on vlan1 the default vlan. That is the only place to set tagged/untagged mode.
Only when I define vlan 4,6 and 7 in the switch it is working when I make the tagged ports a member of those vlans. Without defining vlans the switch just won't forward any frame like the GS105E only untagged frames.
The port connected to the CPE/router is blinking while it sends PADI frames to setup a PPPoE in vlan4. The led of the port connected to the FiberNt is burning green but not blinking.
I think when you want to use this switch you must always define (and know) all the vlans on the trunk and the number must not exceed the 64.
