APDK66
Oct 03, 2015Aspirant
Can't get GS110TP to work as simple as GS105E
For my work I have to check services going over utp links in different vlans. I used a GS105E with its mirror function. I can connect the GS105E without any vlan configuration and all traffic of doze...
- Oct 11, 2015
So I understand I can't use this switch for what I want. I need to check uplinks containing 250+ vlans.
Besides the different configuration effort each time it has a limit of 64 vlans.
I have to look for another solution.
DaneA
Oct 07, 2015NETGEAR Employee Retired
Hi APDK66,
APDK66 wrote:
I did set the ports to trunk on vlan1 the default vlan. That is the only place to set tagged/untagged mode.
Only when I define vlan 4,6 and 7 in the switch it is working when I make the tagged ports a member of those vlans. Without defining vlans the switch just won't forward any frame like the GS105E only untagged frames.
APDK66 wrote:
I think when you want to use this switch you must always define (and know) all the vlans on the trunk and the number must not exceed the 64.
I would agree that proper VLAN configuration is required on the GS110TP. I conclude that not all switches would work instantly with the given default configuration like the GS105E.
DaneA
NETGEAR Community Team
APDK66
Oct 11, 2015Aspirant
- DaneAOct 11, 2015NETGEAR Employee Retired
Hi APDK66,
You may want to check and consider the ProSafe Gigabit PoE/PoE+ Smart Managed Switches that supports 256 VLANs on this link below:
http://www.downloads.netgear.com/files/GDC/datasheet/en/GS516TP-GS728TP-GS728TPP-GS752TP.pdf
DaneA
