tantony
Jul 17, 2019Luminary
Can't register new switch
I had a defective switch, so I contacted Netgear and they send me a free replacement. I'm trying to register the new switch, but it says "this serial number is already registered to another customer...
tantony
Thanks, I send you a PM. I also send an email to Customer.service@netgear.com. I just got this new switch, and its already in my network.
tantony
When I called Netgear for RMA, they said I have 10 business days to return the old switch, but I think I'll hold on to it while this is figured out.
- DaneAJul 17, 2019NETGEAR Employee Retired
I inquired your concern to the NETGEAR Support Team and it seems that the serial number of your GS324TP switch you got as replacement is already registered under your name. Kindly double check it on your end.
DaneA
NETGEAR Community Team
- schumakuJul 17, 2019Guru - Experienced User
Netgear does automatically register replacement devices with the very same account the RMA was requested There is no need to register the device manually.
Regards
-Kurt
