LAN-Turtle
Feb 19, 2018Aspirant
Switch registered twice
The problem of deleting an accidentel double registration does NOT seem to be solved (GS724Tv4 two times registered in my account from 2016).
Receiving no feedback from my registration procedure, I tried it a second time. This time I did get a feedback, but, checking my 'registered products', I find that my switch is listed twice. This leads to problems when starting up and activating a licence key.
.. Therefore again the question: how do i remove the dublicate entry?
Best regards
| LAN-Turtle |
I just got a feedback from the NETGEAR Support Team that your concern is now fixed. Kindly check it. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi LAN-Turtle,
Welcome to the community! :)
I have already inquired your concern to the NETGEAR Support Team. I will post an update here once I got a feedback.
DaneANETGEAR Community Team
Cheers,DaneA
