LAN-Turtle
Feb 19, 2018Aspirant
Switch registered twice
The problem of deleting an accidentel double registration does NOT seem to be solved (GS724Tv4 two times registered in my account from 2016). Receiving no feedback from my registration procedure, I ...
- Feb 20, 2018
I just got a feedback from the NETGEAR Support Team that your concern is now fixed. Kindly check it. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Feb 20, 2018NETGEAR Employee Retired
Hi LAN-Turtle,
Welcome to the community! :)
I have already inquired your concern to the NETGEAR Support Team. I will post an update here once I got a feedback.
DaneA
- DaneAFeb 20, 2018NETGEAR Employee Retired
Cheers,DaneA
