Retired_Member's avatar
Retired_Member
Apr 23, 2019
Can't set Interface IP on Management VLAN - S3300
Hi,
Every time I try to set the IP address for VLAN 100 (Management VLAN) I get an error; Error! Failed to Set 'IP Address' with '10.41.1.1'. It'll then proceed to create an interface IP of 0.0.0.0 and Subnet Mask of 0.0.0.0.
I set this up on the switch (S3300) in the following location; Routing > VLAN > VLAN Routing.
Routing is set to enabled in Routing > IP Configuration.
Any idea why I can't get thsi working?
  • Hi LAB77,
    If you are going to assign an IP to your management VLAN. It should be on System > Management > IP Configuration then set it to Static IP Address. VLAN Routing is used to allow more than one physical port to reside on the same subnet.
    You may check the manual here(page 48).
    JohnCarloV
    NETGEAR Community Team
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi LAB77,
    JohnCarloV
ProSupport for Business
