coyote2
Dec 18, 2016Aspirant
change GS108Tv2 ip address?
I want to change the switch's IP address from 192.168.0.239 to 192.168.1.239 I can't figure out how to do this in the Smart Control Center v1.1.3.2 I'd like to be able to do stuff like update th...
- Dec 19, 2016
Hi coyote2,
Kindly try the steps below:
1. Disconnect the GS108Tv2 from the existing network. The GS108Tv2 will default back to its IP address which is 192.168.0.239.
2. Connect a PC/laptop to a LAN port of the GS108Tv2.
3. Set a static IP address of 192.168.0.210 on the PC/laptop.
4. Open a browser like Google Chrome or Firefox then at the address bar, type 192.168.0.239 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password.
5. Click System > Management > IP Configuration.
6. On the IP Configuration page, select Static IP address then enter 192.168.1.239 in the field provided as well as the corresponding subnet mask and default gateway then click Apply.
7. Connect the GS108Tv2 back to your existing network and set the PC/laptop to Obtain an IP address automatically.
To test the connectivity, connect a PC/laptop directly to the GS108Tv2. Open command prompt on the PC/laptop, then ping 192.168.1.239 which is the static IP address set on the GS108Tv2 and ping the IP address of the router. You should be able to get replies.
Let us know the results.
DaneA
NETGEAR Community Team
coyote2
Dec 20, 2016Aspirant
I'm so sorry I bothered you, because today it appears everything is working perfectly. (Yay!)
Maybe I didn't wait long enough yesterday to give it a chance to work; because today when I upgraded the f/w it seemed to not work for quite a while, but then it turned out it had upgraded when I went back into SCC later.
It was on 5.0.2.22 (the switch had sat unopened for a few years) and now it's on 5.4.2.25.
So much functionality I see on the wealth of config screens, but my needs are simple enough I can't think of anything to change.
Thanks again very much!
DaneA
Dec 21, 2016NETGEAR Employee Retired
You're welcome! :) I'm glad to know that everything is working perfectly.
Since its now working fine, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Happy Holidays! :)
Cheers,
DaneA
- coyote2Dec 21, 2016Aspirant
Oops, sorry I forgot to mark it Solved (again; I prematurely marked it Solved days ago), thanks for the remineder!
Thank you very much for your help!
