Sbod
Oct 18, 2017Aspirant
Compatibility between GS108 ev3switch and UniFi AP AC LR access point
Hi, I have just bought (in Switzerland) a brand new GS 108 ev3 and brand new UniFi access points AP AC LR. When I connect the access points directly to the router, no problem it works, I can see them...
- Oct 20, 2017Hi, many thanks for the reply. I have been able to fix it. Had a kind of conflict with a TV BOX. I wired the TV box directly to the router, bypassing the switch and now the access points work perfectly.
JohnC_V
Oct 20, 2017NETGEAR Employee Retired
Hi Sbod,
Welcome to our community!
The GS108Ev3 is compatible to any Unifi APs as long as you are using a power injector that provides power to it. Do you have any VLANs created on the switch?
Sbod
Oct 20, 2017Aspirant
