mnopnealr
Feb 25, 2021Follower
Complete Newcomer to VLANS - is this possible?
I have never worked with VLANS before. My understanding is the simple (ha!) way of doing VLAN is to let the wired switches (NetGear jgs524pe) assign it based on what port into which things are plu...
DaneA
May 06, 2021NETGEAR Employee Retired
Welcome to the community! :)
What Firewall Router feature requirements are needed to support this?
The Firewall Router should support VLANs. Also, it should be able to serve as DHCP server to each VLAN you will set up.
For the switches, it would be best to consider the Smart Managed Pro Switch Models of NETGEAR like the GS324TP instead of the JGS524PE. The JGS524PE belongs to the Smart Managed Plus Switches family. To learn the difference between the Smart Managed Pro and the Smart Managed Plus Switches, kindly click this link. To know more about the GS324TP, kindly check its data sheet here.
DaneA
NETGEAR Community Team
