sbbasile
Feb 11, 2023Aspirant
Configurationand starlink
Good morning, I have: - rectangular starlink router - ethernet adapter - Additional wifi mesh - Netgear ProSAFE 8 Port Gigabit Plus Switch (GS108Ev3) - devolo CPL Magic 2 WIFI 6 kit (1 CPL LAN ...
- Feb 13, 2023
Actually I wish from Starlink router:
- ethernet cable to my PC via the Netgear switch
- ethernet cable to the devolo CPL Master via the Netgear switch
- the devolo CPL Master will distribute the wifi in all the rooms where a Devolo CPL wifi is connected
schumaku
Feb 13, 2023Guru - Experienced User
Please specify exact what mesh system you have in mind. Some competitors Mesh don't support real networking.
sbbasile
Feb 13, 2023Aspirant
- sbbasileFeb 13, 2023Aspirant
- the devolo CPL Master will distribute the wifi in all the rooms where a Devolo CPL wifi is connected- schumakuFeb 14, 2023Guru - Experienced User
For the optional Ethernet equipped Starlink router and the optional Ethernet, I would expect things would behave like a normal network, allowing the addition of a switch and some more direct connected Ethernet devices.
Not convinced we have the critical mass of collective experience covering the Starlink network environment here in the Netgear community.
Experiencing any specific issue with the additional switch or the 3rd party PLC network devices?
- sbbasileFeb 14, 2023Aspirant
Hello,
I was wondering if it wouldn't be better to replace the Starlink router with a Netgear router because with the Starlink, there is no configuration possible. But if so, which Netgear router should I point to?
I don't have any problems with my peripherals but let's say that I would like the whole thing to work optimally and in complete safety.
Thank you
