Caprice24
May 14, 2022Tutor
Orbi 6e cannot connect to Starlink
Well I wasn't able to get the Orbi 960 to get an Internet connection with Starlink V2, using the Starlink Ethernet adapter, so have filed a trouble ticket with Netgear. The unit is getting an IP address from the Starlink, as I have set up the Dynamic IP address option, and I spent 3 hours with them on the phone. They were helpful but not able to resolve the issue. They admit this is foreign territory to them, and they are escalating to tier 2 support.
It may just be a configuration issue, but as we are seeing more people sign up for Starlink service now that is being rolled out in major metropolitan areas, such as the SF Bay Area and Silicon Valley, it will behoove Netgear to issue some kind of FW patch to address this Starlink setup issue.
Likely if it is affecting me, it will affect others. It should be plug and play, or have some kind of wizard that would detect Starlink hardware, and then make the appropriate setup changes.
To add further details to my previous reply for the Orbi 960 (AXE110000) Router, I was able to get a direct laptop connection to the Ethernet adapter working with the Starlink V2, so I know that Starlink is giving an IP address 192.168.1.158 to the laptop that allows it to connect to the Internet.
The problem is when I hook up the Orbi.
I have tried connecting it with a static address tied to 192.168.1.158, as well as a dynamic address set by Starlink. I have also experimented with Get DNS automatically from the ISP vs. using the Google DNS of 8.8.8.8 and 8.8.8.4. Also, tried using the Starlink MAC address (as well as my laptop's) instead of the default MAC address, all to no avail.
Under guided instruction from Netgear Tech support, did a hard reset of the Orbi Router with a paper clip, then disconnected power from both Starlink and Orbi, and then repowered on Starlink to make sure it was connected to Internet via Starlink's built in Wifi, and then repowered up Orbi in each one of those configurations above, using dynamic IP mode and in Router mode. Nada.
Also tried static configuration of IP addresses, under "Advance Home" screen on the orbilogin.net page to the Orbi unit, I see that the IP address for the Orbi "Router Information" is 10.0.0.1, and the IP address for the Orbi "Internet Port" for static configuration is 192.168.1.158 with IP subnet mask of 255.255.255.255 and DNS 8.8.8.8 and 8.8.8.4.
Similar results for dynamic IP configuration with the Orbi, no Internet (and the red light lights up under the Orbi after boot).Note here is the successful laptop connection directly to the Ethernet adapter on Starlink (eg No Orbi in the looop): using ipconfig from Windows 10 cmd window:
IPv4 Address 192.168.1.158
Subnet Mask 255.255.255.0
Default Gateway 192.168.1.1
WIndows Network Profile also shows that DNS was Automatic (DHCP) Automatic IP assignment, and IP address is 192.168.1.158 and IPv4 DNS server. As 192.168.1.1 with subnet mask 255.255.255.0
The above set up with the laptop works perfectly with Starlink Ethernet.Also have tried putting the Orbi in "Access Point" mode, with the same results, no Internet.
If anybody has any ideas of how to configure the Orbi differently so that it works with the Starlink V2, I'm all ears!
Netgear Tech support has promised a callback with their elite Tier 2 tech support engineers as they themselves are stumped.As mentioned before, if I connect the Orbi to a Comcast/Infinity cable modem, there are no issues, and I even downloaded and installed the latest Firmware for the Orbi, and it connects perfectly to the Internet.
So don't believe there's a hardware issue, am pretty certain it's configuration issue with Orbi and the Starlink V2.
Caprice24 wrote:Also tried static configuration of IP addresses, under "Advance Home" screen on the orbilogin.net page to the Orbi unit, I see that the IP address for the Orbi "Router Information" is 10.0.0.1, and the IP address for the Orbi "Internet Port" for static configuration is 192.168.1.158 with IP subnet mask of 255.255.255.255 and DNS 8.8.8.8 and 8.8.8.4.
WIndows Network Profile also shows that DNS was Automatic (DHCP) Automatic IP assignment, and IP address is 192.168.1.158 and IPv4 DNS server. As 192.168.1.1 with subnet mask 255.255.255.0The Orbi seems to be getting its IP address but the internet access to connected devices doesn't work -- That's the only issue, right? One thing I see is that the subnet mask is different for the Orbi vs. what your PC has, so suggest trying 255.255.255.0. For my Orbi AXE + Comcast the subnet mask is 255.255.248.0.
One test from your PC connected to Orbi connected to Starlink is to try tracert 8.8.8.8 and see where it goes. On my Windows PC + Orbi + Comcast I see the following (going through my Orbi at 192.168.1.1 to 96.120.89.157, which a google search says belongs to Comcast):
C:\Users\mikey>tracert 8.8.8.8 Tracing route to dns.google [8.8.8.8] over a maximum of 30 hops: 1 24 ms 3 ms 9 ms 192.168.1.1 2 19 ms 17 ms 19 ms 96.120.89.157 3 17 ms 21 ms 14 ms 96.110.179.13 4 23 ms 12 ms 20 ms po-2-rur01.sffolsom.ca.sfba.comcast.net [69.139.198.5] 5 20 ms 18 ms 46 ms be-209-rar01.santaclara.ca.sfba.comcast.net [68.85.57.241] 6 24 ms 184 ms 16 ms be-299-ar01.santaclara.ca.sfba.comcast.net [68.86.143.93] 7 33 ms 120 ms 92 ms 96.112.146.22 8 34 ms 23 ms 17 ms 142.251.70.37 9 24 ms 17 ms 22 ms 142.251.65.127 10 22 ms 23 ms 18 ms dns.google [8.8.8.8]
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #2 first...
https://community.netgear.com/t5/Orbi/RBR50-with-StarLink/m-p/2190141
I have the Starlink V2 (rectangular version 2) system, and recently installed the Starlink Ethernet adapter, which allows one to connect devices up directly to the Starlink router.
I have the Orbi 6e quad band mesh system (AXE110000), and have tried without luck to connect to the Starlink via their Ethernet adapter. I have also tried turning on the Orbi's AP mode as well as the normal default router mode, and have also tried changing the DNS server to be 8.8.8.8 but too didn't work. Of course, power cycling both Starlink and Orbi's (all three of them) and disconnecting/reconnecting cables and re-power cycling was tried.Has anyone been able to get Starlink V.2 (rectangular dishy) to connect to the Orbi 6e? If so, please publish your steps to make this work.
Note that I was able to to install the Orbi system and get it to work with my Xfinity Cable modem service and install the latest updates/patches from Netgear, as well as access the Internet fine.
The problem is just doesn't seem to want to obtain a valid IP address from the Starlink Wifi V2 and access the Internet.Thanks,
Nick
This RBRE960 owner seems to have it working with Starlink; https://www.reddit.com/r/Starlink/comments/t246sd/netgear_orbi_router/. There are a lot of other reddit posts about Orbis, some saying it can take a long time for the Orbi to acquire an IP address.
I'm surprised that you could not get AP mode to work. Assuming you can plug a wired PC into the Starlink equipment, get an IP via DHCP and access the Internet then the Orbi base router should be able to do exactly the same thing. Is it unable to acquire an IP via DHCP plugged into the same ethernet port as a test PC?
- JublesAspirantI'm currently having the same issue. Did you come across a fix? I saw the post about a network switch, but that's about it for advice. Did I miss something?
Any help would be great.
Thanks,
Jubles.- No unfortunately the added switch is the only current fix that I know of.
- tcard296Initiate
I had the same problem. I bought this https://www.bestbuy.com/site/netgear-8-port-10-100-1000-mbps-gigabit-plus-managed-switch-gray/9063009.p?skuId=9063009 and connected it between Starlink and Orbi. Problem solved. I don't know why it worked, just heard that it might and tested it. Make sure you put Starlink in Bypass Mode so it disables the Wifi and becomes basically a modem for access to the internet. Good Luck.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- matthewtdeanAspirantI purchased and installed a NG GS105NA placing it between the starlink and the Orbi and still no internet connectivity. Thoughts?
starlink - NetGear - Orbi
- billie_aAspirant
I started off without the ethernet adapter, but obviously needed a wired connection to the starlink router. I purchased a generic wi-fi extender with a wired port, paired it to the starlink wi-fi name, and orbi 6e network works fine.
I then purchased the starlink ethernet adapter, and could not get it to work reliably. In fact, it showed the same symptoms I had previously experienced with the orbi 6e and a netgear LM1200 LTE modem with Verizon. That is the system would gain an IP address, then a few minutes later, it would drop the connection and request a new IP address. I thought it was related to somehow negotiating a very short lease time, but other messages here indicate it might be the ethernet connection bouncing first (as opposed to the loss of lease resetting the port).
I have tried the orbi 6e against the ethernet adapter both in starlink router mode and in starlink bridge mode. both experienced the same problematic behavior. But with the wi-fi extender (extending starlink wi-fi and providing an ethernet port), the orbi works fine.
If the problem is really something to do with the hardware connection, and is solvable with a bridge, then I will give that a try. I have used the ethernet connection from starlink directly to an eero pro without any issues. I've recently put a bridge in the middle so that a vpn device could also be isolated from the eero network (and the orbi network). But it didn't occur to me to try the orbi wired connection again using the switch. I will give that a try. I'd love to remove the wi-fi extender from this setup.
btw: I'm using the orbi lan setup configuration of 192.168.64.1/18 to avoid address overlaps with starlink. The orbi s/w doesn't seem to take the subnet mask into account, and will only give out 192.168.64.2 through 192.168.64.255. That is an unrelated issue though (and still plenty of addresses for me). I can always assign fixed addresses using the higher address bits.
I think one suggested that placing a non managed LAN switch in between the RBR and Startlink adapter helped them...Like NGs GS-105/108 series may work.
- veriatechAspirant
I am an IT & Networking professional consultant and currently assisting a client get their Starlink & Netgear Orbi system talking. I've jumped through all the "normal hoops" to get these two devices talking (as others here have), to no avail. As one poster mentioned, a MANAGED Netgear GS108T switch between the Starlink ethernet adapater and the Netgear router seemed to do the trick. I am curious though whether a managed switch is needed for this or a simpler unmanaged switch. What was the reason for implementing a managed switch?
Also, what is the port labeled "Ethernet 2.5G" for on the back of the Netgear device? At this point, I am simply looking at pictures my client is sending to me as he is in a very remote / hard to get to location. An on site visit may be in order but I want to make sure I understand all the variables whether making the trip.
Thanks all!
- Robert80Initiate
Starlink Ethernet adapter, I connected to TRENDnet 5-Port Unmanaged Gigabit GREENnet Desktop Metal Switch from switch to Orbi 690 works great 320 down load speed
Glad you got it working and letting us know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
