m4chine's avatar
m4chine
Follower
Mar 15, 2025
Configure a VLAN for the Smart Management Plus Web Interface
Is there a way to configure the VLAN for the Smart Management Plus Web Interface for managing the JGS524Ev2 and GS308E switches? Latest firmware, v2.6.0.50 and v1.00.11EN respectively.   It appears...
  • schumaku's avatar
    Mar 16, 2025
    No.
    m4chine wrote:
    It appears the Smart Management Plus Web Interface is available to any VLAN/PVID physically connected to the switch.
    Correct.
    Not A firmware question, it's about hardware. Much more, (most of) these Plus switches are built on unmanaged cores, wothout a management VLAN. The NDSP protocol and the simple Web UI is implemented on a 8051-class uC, the simple IP stack does not know about tagging, such frames are simply ignored, it does handle just untagged IPv4 frames.
ProSupport for Business
