jeremy-s
Nov 05, 2022Aspirant
Connecting MS510TXPP to XS505M via AXM761 SFP+
Hi, I've got a MS510TXPP and I'm trying to connect it to an XS505M via two AXM761 SFP+ modules. I've got an existing fiber cable ran between two locations. The cable I've got running between...
- Apr 12, 2023
FWIW, AXM763 fixed it. The standard range module didn't have enough for that long of a run but the long range module works fine. 👍
schumaku
Nov 06, 2022Guru - Experienced User
The reach of 10 GbE laser modules over OM2 is limited to about ~80 meters only.
https://community.fs.com/blog/advantages-and-disadvantages-of-multimode-fiber.html
- jeremy-sNov 06, 2022Aspirant
I was suspicious of the link length so I did some further reading last night.
The AXM761 lists a link length of 108' with 62.5/125 OM1/OM2 cable. The OM2 cable I have is 50/125, but maybe that 108' is still the limit, even with 50/125?
The AXM763 might be the solution. It's listed as 10Gig for 722ft on 62.5/125 OM1/OM2 multimode.
Think the AXM763 is the ticket?
- jeremy-sApr 12, 2023Aspirant
