davidbeard
Sep 29, 2017Aspirant
Connecting multiple GS728TP and GS752TP switches together in a rack
We've recently replaced our Prosafe Plus JGS524E switches with both (4) GS728TP and (2) GS752TP switches in our main server rack. We are planning to redesign our flat network using multiple VLANs. ...
- Oct 01, 2017
Hello @davidbeard,
Welcome to the community!
You can cascade the switches (a mix of GS728TP and GS752TP) using either the SFP ports or ethernet ports. It is more applicable to use the SFP ports to cascade 2 or more switches if the distance between each other is more than 100 meters. There is no limit on the number of NETGEAR switches that can be daisy chained or cascaded together. However, the best practice would be up to 2-3 switches cascaded. It is because the more switch that you cascade will add latency on the network.
The compatible SFP modules for both GS728TP and GS752TP switches are AGM731F, AGM732F and AFM735. Kindly check their differences below:
As reference, kindly check the data sheet of the GS728TP and GS752TP switches here.
DaneA
NETGEAR Community Team
DaneA
Oct 01, 2017NETGEAR Employee Retired
Hello @davidbeard,
DaneA
