davidbeard
Sep 29, 2017Aspirant
Connecting multiple GS728TP and GS752TP switches together in a rack
We've recently replaced our Prosafe Plus JGS524E switches with both (4) GS728TP and (2) GS752TP switches in our main server rack. We are planning to redesign our flat network using multiple VLANs. ...
- Oct 01, 2017
Hello @davidbeard,
Welcome to the community!
You can cascade the switches (a mix of GS728TP and GS752TP) using either the SFP ports or ethernet ports. It is more applicable to use the SFP ports to cascade 2 or more switches if the distance between each other is more than 100 meters. There is no limit on the number of NETGEAR switches that can be daisy chained or cascaded together. However, the best practice would be up to 2-3 switches cascaded. It is because the more switch that you cascade will add latency on the network.
The compatible SFP modules for both GS728TP and GS752TP switches are AGM731F, AGM732F and AFM735. Kindly check their differences below:
As reference, kindly check the data sheet of the GS728TP and GS752TP switches here.
DaneA
NETGEAR Community Team
davidbeard
Oct 04, 2017Aspirant
Thank you for your response. So am I assuming correctly that when using SFP for less than 1-foot that this would not be a recommended practice? That being said, our current setup is coming from our SonicWALL we feed a DMZ switch that separates the LAN and WAN. From the DMZ switch it then feeds a GS752TP switch which is basically a distribution switch. The remaining (3) GS728TP switches then use their port 24 to connect back to the GS752TP. Would this setup cause the latency you were referring to? If so, what would be best practice to accomplish this? Thanks again for the great information and help.
DaneA
Oct 04, 2017NETGEAR Employee Retired
Thanks for the feedback. You could still make use of the SFP ports to cascade switches even if the distance is just 1-foot. It is just alright. In our laboratory, some switches are cascaded using the SFP ports even if their distance between each other is just about more or less than 1-foot.
About your current setup, I believe its just fine. You may want to perform an iPerf test within your existing network setup. Kindly check the links below about iPerf:
IPERF: How to test network Speed,Performance,Bandwidth
Basic Network Testing with iPerf
DaneA
