charlie663
Jul 20, 2025Aspirant
Connection issues in GS324TP
Hi all,
I have a GS324TP model which is causing me a terrible headache.
Connecting devices through the switch it goes really slow. I went to the simple case of a PC, a switch and a router.
If i connect my PC directly to the router, everything goes fine. But if i connect my PC to the switch and the switch to the router, it goes really slow. But not only internet, but also intranet.
Any browser sends the ERR_CONNECTION_RESET error and, of course, i cannot do any internet test speed either.
I reset the switch as well (just confirming the switch was the problem) and everything continues in the same way.
Now, I disconnected it until i got any answer....
If you could help, it would be appreciated.
charlie663 wrote:
Is there any way to see logs in switch?
It is a smart switch, so you can see port status, etc.
You might want to revew the manual:
- https://www.downloads.netgear.com/files/GDC/GS324T/GS324T_GS324TP_GS348T_UM.pdf
Have you tried different switch ports for both connections?
Any chance it is cabling?
- charlie663Aspirant
I didn't try different switch ports, but cabling cannot be, because i used same cables to connect directly to the router. And same cables worked.
