smudgebutter's avatar
smudgebutter
Convert GS108Tv2 to unmanaged?
Our IT security setup is being changed from using to two GS108Tv2's as firewalls to another device plus an unmanaged switch.  My question is - Can I configure (or un-configure) this managed switch to...
  • Carl_z's avatar
    Apr 02, 2018
    Hi smudgebutter,
    Welcome to the community!
    I think your ideal can work. Just clear the current configurations of GS108Tv2(you can perform a factory default)
    If there any other issue when using it please keep us informed
    Thanks
    Carl
    Netgear Employee
ProSupport for Business
