smudgebutter
Apr 02, 2018Aspirant
Convert GS108Tv2 to unmanaged?
Our IT security setup is being changed from using to two GS108Tv2's as firewalls to another device plus an unmanaged switch. My question is - Can I configure (or un-configure) this managed switch to...
- Apr 02, 2018
Welcome to the community!
I think your ideal can work. Just clear the current configurations of GS108Tv2(you can perform a factory default)
If there any other issue when using it please keep us informed
Thanks
Carl
Netgear Employee
smudgebutter
Apr 03, 2018Aspirant
Thank you. We will give that a go and see if it works as expected then. Much better solution than toss and replace.
schumaku
Apr 04, 2018Guru - Experienced User
It still remains a manageable switch. Your IT security seems to prefer an unmanaged switch to minimise the number of potential attack vectors. Not sure this is the right way to go, but that's another discussion.
