TheRavan's avatar
TheRavan
Follower
Oct 19, 2021
Daisy Changing two POE Switches off of a NightHawk
I am needing to get POE to the other side of the house and I can't run multiple Cat5/6.
Here is what I am thinking.
Nighthawk to Netgear 5-Port GS305E or a 5-Port POE GS305EPP . About a 20 foot run.
GS305E/GS305EPP to Netgear 8 port POE GS308EPP.  About a 30 foot run.
The GS308EPP with host 2 outdoor PTZ cameras and a Fire TV.
I want the 8 port for future growth for maybe more PTZ cameras and a computer.
Also can you daisy change to POE switches?
Thank you in advanced for your help.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    TheRavan,
    Welcome to the community! :)
    Yes, these setup can be implemented.
    Yes, you can daisy chain or cascade a number of PoE switches because there is no limit on it.  However, the good practice would be up to 2-3 switches daisy chained.  Its because the more switch that you daisy chain will add latency on the network.
    DaneA
    NETGEAR Community Team
    • schumaku's avatar
      schumaku
      In case the concern is PoE you don't have to worry. A IEEE standards based PoE switch does not blindly supply power on a PSE (power source) port. This requires a negotiation with the PD (powered device) connected, if there is none it's a plain normal Ethernet port.
      -Kurt
ProSupport for Business
