RobFarnsworth
Apr 08, 2016Aspirant
Device View GS724T-400EUS not working
Hi. I've just installed the above switch only to find that the Device View displays the following no matter which browser is used and after checking Java. /* Non stacking*/ You need the Java P...
- Apr 16, 2016Thanks for the suggestions. After wasting days on this problem the only solution is to use an early version of Java 7 with Internet Explorer ignoring all the security warnings. This of course is now a security issue to use on the Internet. Netgear should not be allowed to sell a product like this. I now have to dedicate a laptop purely for this function.
Do not buy this product unless you are happy to do the same.
RobFarnsworth
Apr 16, 2016Aspirant
