RobFarnsworth
Apr 08, 2016Aspirant
Device View GS724T-400EUS not working
Hi. I've just installed the above switch only to find that the Device View displays the following no matter which browser is used and after checking Java. /* Non stacking*/ You need the Java P...
- Apr 16, 2016Thanks for the suggestions. After wasting days on this problem the only solution is to use an early version of Java 7 with Internet Explorer ignoring all the security warnings. This of course is now a security issue to use on the Internet. Netgear should not be allowed to sell a product like this. I now have to dedicate a laptop purely for this function.
Do not buy this product unless you are happy to do the same.
RobFarnsworth
Apr 16, 2016Aspirant
The Smart Control Centre only discovers the switch and not any devices connected to it. This may be useful if you have numerous switches but apart from that it's a waste of time.
