PeterStr's avatar
PeterStr
DHCP not working - many GS108T v2 and GS724T v3
Hi,
I have many GS108Tv2 and GS724Tv3.
We switched the subnet within the 192.168 group. Only a part of the switches followed.
The rest of the switches are now on IP adresse 192.168.0.239
I tried to change IP-address with SmartControlCenter, where I succeded at some switches, using fixed IP-adresses in the new subnet. Than I told these switches to get address by DHCP. But they went back to 192.168.0.239
What can I do that they follow to the fitting subnet?
Thank you.
  • Thank you, I rebooted them by taking off the power supply - than I gave them fixed IPs (sorry).
    Thank you for your help;-)
  • schumaku's avatar
    schumaku
    No idea what happened when using the SCC.
    Reboot each switch while the connection to the router/DHCP server is available.
    • PeterStr's avatar
      PeterStr
ProSupport for Business
