BR_Geek83
Mar 16, 2023Follower
Difference between GS752TP-200NAS an GS752TPP Switches
We are looking to upgrade our managed switch for our small business. I am trying to figure out the difference between the following managed switches: GS752TP-200NAS (I believe this is V2 of...
- Mar 16, 2023
BR_Geek83 wrote:
1) What are the difference in functionality?
The difference is the total PoE+ budget available on the PP variant.
BR_Geek83 wrote:
2) Which is the "newer" switch ? I am looking for longevity
All models on the data sheet are from the same generation.
BR_Geek83 wrote:
3) Do both require a "Cloud Subscription" to get full management capabilities?
Only if you need the cloud management capability.
Compare the data sheet FMI here:
https://www.downloads.netgear.com/files/GDC/GS728TPv2/GS728TPv2_GS728TPPv2_GS752TPv2_GS752TPP_DS.pdf
schumaku
Mar 16, 2023Guru - Experienced User
