cjn_bjss
Nov 29, 2017Aspirant
dropped packet using sfp fibre lag between x2 sets of stacked GS728TS / GS752TS switches
Hi There, Running into a slight issue with the LAG setup to join x2 office floors together onto the company lan. I have the following configuration presently: Ground Floor: x2 GS752TS x2 GS...
- Dec 08, 2017
cjn_bjss,
I believe it doesn't detect any loops within those switches that is why it is showing disabled. You may try connecting a cable from g1-g2 on the same switch just to check if STP will work. Even if you enabled LAG and the configuration from the other switch is incorrect, definitely, it will not show anything in the stats page. Make sure that both ends have the same configuration in setting up LAG and even in Stack configuration.
