steve8
Jun 14, 2021Aspirant
Dual WAN aggregation to double WAN throughput - Is it possible?
Hello, I am looking to set up WAN Aggregation for two WAN connections using the Netgear MS510TX switch. I wondered if it was possible, and if someone would be kind to share how I would go about se...
steve8
Had to check it, this CPE does really come with a 5 GbE port. Again leaving alone of the network this CPE does connect to will ever deliver this kind of performance, to reach the theoretical 4.14 Gb/s down and 660 Mb/s up, you need a device able to deal with these >4Gb/s so a computer with a 5 GbE Ethernet port (or faster). If the aim is sharing this theoretical peak bandwidth to multiple systems, the MS510 Series switches could deal with this.
To make use of this with a MultiWAN router, the device would need to become a pure "modem" only, providing the public WAN IP only.
schumaku I was hoping to use the MS510 and its L3 functonality to bond the two WANs. I have not found a Multi WAN router that supports 5 GbE connections, Do you know of any suitable Multi-WAN routers with Multi-Gig support?
steve8 wrote:The second WAN is the NetComm NDD-0300 VDSL2 modem. The NetComm is strictly a modem only as far as I know and requires a router for routing.
A multiWAN router which can terminate the xDSL (e.g. PPPoE) and handling the NAT for the LAN could handle this.
schumaku I assume that the MS510 will not be able to handle this task as it does not have NAT.
Would the Netgear M4200 (GSM4210P), with complete L3 functionality, allow me to use the one switch for WAN bonding if the MS510 is too limited?
Thanks for your help!
schumaku
Jun 15, 2021Guru - Experienced User
For serving the 5G router to the LAN, both switches are fine.
The point is that you need a true Dual- or Multi-WAN NAT router offering the required bandwith (and Ethernet technology), Internet CPEs able to provide a plain IP connection (no NAT, no routing, ...) and for the xDSL ones the ability to handle the protocol encapsulation (like PPPoE). These are all not features available on almost "any" switch.
- steve8Jun 15, 2021Aspirant
I think the draytek vigor 3910 ticks all of the boxes. I could use its Dual WAN function and rely on SFP+ modules to support 5 GbE for the CPE and 10 GbE to my main computer. This router would also handle the xDSL side.
What do you think? I hate the price tag and I'm hoping that there is another much cheaper Dual WAN router with 2 - 3 SFP+ modules so that I can do the same thing
