Niall_Lynch
Jan 24, 2022Follower
Find IP Address of GS724Tv4 I know the MAC Address
I have a GS724v4 which had it's IP address changed a few years back. There are a couple of VLAN's on the switch and I need to access it to set up a new vLAN. The problem is that Idon't know the static IP Address but I do know the MAC address. Is there any way to discover this
- rhydianwynAspirant
Another option you may be able to use is a program such as Angry IP Scanner. If you know which VLAN/address range your switch's mnagement interface is on you can connect a PC to it and run the program with the MAC address and MAC vendor fetchers enabled, then sort the resulting list by MAC address or MAC vendor.
