Mike_44
Nov 18, 2017Follower
Finding the IP address of a switch using a MAC
Hi.
I need to find the IP address of my GS108T switch on my network.
An IP scanner is not locating it - no MAC address matchup.
It does not show up in the router's DHCP server - no MAC address matchup
"ARP -a" does not find it.
I have a MAC so the ProSafe Plus utility does not work.
Broadcast Ping did not find it.
Any other thoughts would be helpful.
Thanks
Mike
- Yeah, I guess the Smart Control Center software is Windows only.
The default IP address is 192.168.0.239. If that doesn't work, then you could perhaps try Wireshark and sniff a packet or two from the switch. Power cycling might encourage the switch to emit something.
1 Reply
