jlanka
Feb 22, 2017Tutor
Firmware download GSS116E only shows Prosafe Plus config utility
GSS116E, when I click on firmware and software downloads it only shows me the prosafe config utility. Where is the firmware?
DaneA
Mar 07, 2017NETGEAR Employee Retired
The firmware for the GS116E will not work on the GSS116E. The GSS116E might get brick if you try to upload a firmware from other switches.
DaneA
NETGEAR Community Team
- jlankaMar 07, 2017Tutor
OK thanks. So when will firmware for the GSS116E be available?
