jlanka
Feb 22, 2017Tutor
Firmware download GSS116E only shows Prosafe Plus config utility
GSS116E, when I click on firmware and software downloads it only shows me the prosafe config utility. Where is the firmware?
DaneA
Apr 02, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to download firmware v1.0.0.5 and upload it to your GSS116E switch?
If ever you were able to upload firmware v1.0.0.5 to your GSS116E and everything is working fine, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Eaglehawk
Jul 20, 2017Apprentice
This has happened again, is there a reason why the 1.0.0.5 firmware was pulled? (I've already upgraded, but I'm concerned about why it's suddenly disappeared)
