gtb_'s avatar
gtb_
Follower
Dec 05, 2022
Firmware update for Netgear GS748Tv5 - Issue Firmware not supported
Trying to update the firmware for a client site with 4* 48 port Netgear GS748Tv5 switch on site. I am planning to use the SMART CONTROL CENTRE for the firmware update.
Issue : at the final stage of update control centre shows up with the error - "THE SELECTED DEVICE DID NOT ACCEPT THE FIRMWARE FILE"
Following instructions from KB -
https://kb.netgear.com/24699/How-do-I-use-the-Smart-Control-Center-to-upgrade-the-firmware-of-a-smart-switch
Link from where i got the firmware
https://www.netgear.com/support/product/GS748Tv5.aspx#download
Current firmware version - 6.3.1.19
The ports are untagged on all 4 switches
This is my first time doing a firmware update for a netgear product - any help/Tips and guidance would be appreciated.
  • schumaku's avatar
    schumaku
    SCC is an obsolete legacy application, still workable however. Preferred way is upload the firmware image to one of the two available image areas, and activate it before the restart.
    Double check these are GS748Tv5 (GS748T-500xxx) models. Have expanded the archive and extracted the image file gs7xxt-v6.3.1.43.stk ?
    Follow the older version release notes - it's much more informative for newcomers in this task https://kb.netgear.com/000038699/GS716Tv3-GS724Tv4-GS748Tv5-Firmware-Version-6-3-1-19
    • PapaPeteH's avatar
      PapaPeteH
      Guide
      THANK YOU! Yes, those instructions for HTTP firmware install DO work. SCC appears to work, but in reality messes up the firmware upload as I've documented elsewhere.
ProSupport for Business
