WernerV
Jul 13, 2017Aspirant
Firmware Update Problem Gs748TS v4
Good Day I have purchased a used switch to learn more about network switches. The latest firmware was downloaded from netgear site, but after it was installed, was indicated in smart control c...
- Jul 13, 2017
Hi WernerV,
Welcome to NETGEAR community!
I want to confirm that your switch is GS748Tv4 or GS748TS? I can find version 5.0.2.18 under GS748Tv4, which is we only can get the oldest version.
If you downloaded the latest version 5.4.2.30, after installing, the swich will reboot and all ports lights are yellow, the restart may take several minutes, please do not power off or power on before the reboot process is complete.
Please make sure that you upgrade the fimware follow release notes.
NETGEAR Employee
ElaineP
Jul 13, 2017NETGEAR Expert
Hi WernerV,
NETGEAR Employee
WernerV
Jul 14, 2017Aspirant
Hi Elaine
Thank you for assisting.
It's GS748Tv4 and all sorted, now.
Kind Regards
Werner
