Arjan25
Sep 06, 2021Aspirant
Firmware update
Hello, I`m living in Holland, so my Englisch is not very good. Butt i have a question about my new switch. There are new firmware versions butt i dont now how to update them. I have to log in ...
- Sep 11, 2021Good afternoon, The problem has been solved. I have been in contact with Netgear support and I made a mistake with connecting my TP Link deco. I knew I had to connect it to the modem first and only then to the switch, but I still did it the other way around. This changed and then I could log in and install the latest firmware. Greetings Arjan
Arjan25
Sep 07, 2021Aspirant
Hallo Kurt,
I`m sorry it was 192.168.0.239 that won`t work.
I already used this program before opening this topic. But even with the given ip address, login is not possible.
There is also an ip address on the switch, but unfortunately that doesn't work either, I already tried that yesterday.Why has this way of updating been made so difficult?
Greetz Arjan
schumaku
Sep 11, 2021Guru - Experienced User
Is the switch connected to your local network and the Internet router, or is it connected direct to your PC?
It's not difficult to update - however, to establish a communication by IPv4, the switch IP address must be in the same IP subnet like at least one connected computer adapter.
- Arjan25Sep 11, 2021AspirantGood afternoon, The problem has been solved. I have been in contact with Netgear support and I made a mistake with connecting my TP Link deco. I knew I had to connect it to the modem first and only then to the switch, but I still did it the other way around. This changed and then I could log in and install the latest firmware. Greetings Arjan
- schumakuSep 11, 2021Guru - Experienced User
Great, thank you for the update!
