Arjan25
Sep 06, 2021Aspirant
Firmware update
Hello, I`m living in Holland, so my Englisch is not very good. Butt i have a question about my new switch. There are new firmware versions butt i dont now how to update them. I have to log in ...
- Sep 11, 2021Good afternoon, The problem has been solved. I have been in contact with Netgear support and I made a mistake with connecting my TP Link deco. I knew I had to connect it to the modem first and only then to the switch, but I still did it the other way around. This changed and then I could log in and install the latest firmware. Greetings Arjan
schumaku
Sep 11, 2021Guru - Experienced User
Is the switch connected to your local network and the Internet router, or is it connected direct to your PC?
It's not difficult to update - however, to establish a communication by IPv4, the switch IP address must be in the same IP subnet like at least one connected computer adapter.
Arjan25
Sep 11, 2021Aspirant
- schumakuSep 11, 2021Guru - Experienced User
Great, thank you for the update!
