GhengisTom
Nov 01, 2021Aspirant
Firmware Updates on every switch?
Howdy Folks - new to the details of networking and can use some guidance on firmware updates. I've replaced most of my cat5e cable with Cat6 out of necessity and centralized all ethernet drops in...
schumaku
Nov 02, 2021Guru - Experienced User
All these switches are standalone devices, requiring their own firmware.
GhengisTom wrote:
When I try to login to admin screens, it can only see the primary switch.
No idea on how you try this login. Each switch requires an IP address, usually these switches are configured to request the IP address from the local network DHCP server. Why ever (for simplicity), these switches try for a short time only, to fall-back to the default IP address.
I suggest to reboot all these other switches while the primary switch is and the router connection is up and running.
Then use the NETGEAR Switch Discovery Tool (NSDT) to find these switches IP addresses, or consult your router DHCP server or it's logs or the attached device list, based on the MAC address printed on the product label as a reference.
-Kurt
