slv_slv
Apr 06, 2018Aspirant
FS526T and latest firmware
Hello
I'm looking for latest firmware for FS526T (not v2) I know topic https://community.netgear.com/t5/Smart-Plus-Click-Switches/FS526T-v1-Latest-Firmware-Missing-from-Download-File/td-p/11237...
- Apr 11, 2018
Hi slv_slv,
I inquired your concern to the higher tier of NETGEAR Support and got a feedback today. As per the higher tier of NETGEAR Support, the latest firmware for the FS526T is already posted on its product page here which is named FS526T Smart Switch software Version 1.1.0 (v1_1_0_0412). This firmware was released way back 2004 and no newer firmware was released after that version.
You can download the latest firmware software Version 1.1.0 (v1_1_0_0412) for the FS526T Smart Switch also here. For the HEX file, you will need to unzip the FS526T Smart Switch Software Version 1.1.0 which is a zip file. Then, there is another zip file inside it which is fs526t_v1_1_0_0412 that you need to unzip to reveal the HEX File. Refer to the image below:
DaneA
NETGEAR Community Team
schumaku
Apr 07, 2018Guru - Experienced User
In a reply to the referencd thread DaneA wrote:
"I apologize for the late response. I'm afraid to inform you that v2.05.03 is not a firmware version for the FS526T switch. It is just an updated version of the Smart Wizard Utility."
Interesting that there that the real firmware (the hex file) is not available on the downloads, and things are as misleading as before.
