CSLLC
Feb 05, 2017Aspirant
FS728TP continuos reboot loop
Ok, I literally just received this off Amazon about 1 hour ago. Out of the box I connect to the servers data port, config and up and going. No issues. I am poking around with the Smart Control s...
- Feb 06, 2017
DaneA,
I followed your suggestions and the results are the same.
At this point I would have to say this is a defective unit.
Do I need to contact NETGEAR and coordinate a exchange with them or with Amazon. This unit is not even 24 hours old.
Thank you in advance,
CSLLC
CSLLC
Just checked the TASK report in the SCC and it shows that it successfully downloaded and installed the FW update. It also shows a successful reboot.
CSLLC
On a whim I changed ports on the switch and too my suprize I got a green light. So I ran the SCC and it found the switch but with a IP of .238 instead of .239.
I checked to see that static was selected and not DHCP. Confirmed.
I noticed that all setup info was gone, I.E. description, location etc.
Then I noticed that the devices MAC address has been changed to all zeros with the last digit being 01.
There is no longer a factory reset option in the SCC. I cannot factory reset on front panel.
I tried to install the FW again and again received confirmation that it was successful in the task list.
I tried to change the IP back to .239, no joy, it fails.
I try to access the web interface, no joy it times out.
I downloaded the original FW and attempted to install, no joy I receive a timeout notification in the task list.
- DaneAFeb 06, 2017NETGEAR Employee Retired
Hi CSLLC,
Welcome to the community! :)
Kindly try the steps below:
1. Disconnect the FS728TP from your existing network and make sure its turned on. Get a straightened paper clip.
2. Insert the paper clip to the factory defaults hole then press and hold the factory reset button inside it for 30 seconds.
3. After 30 seconds, turn off the FS728TP while you still continue to press and hold the factory reset button. Wait for 5 seconds.
4. After 5 seconds, turn on the FS728TP while you still continue to press and hold the factory reset button. Wait for another 5 seconds.
5. After 5 seconds, release the paper clip from the factory reset button. Wait for the FS728TP to boot up properly.
6. Connect a PC directly to the FS728TP and set a static IP address of 192.168.0.210 to your PC.
7. Open a browser like Google Chrome or Firefox then at the address bar of it, type 192.168.0.100 then press Enter. Login to the user interface of switch. Enter "admin" as the username and "password" as the password with no quotation marks.
Note: The default IP address of FS728TP is 192.168.0.239.
Are you able to access its web-GUI? If ever the FS728TP switch still continuously reboots on its own, then it means that the switch has failed and needs to be replaced.
DaneA
NETGEAR Community Team
- CSLLCFeb 06, 2017Aspirant
DaneA,
CSLLC
Did you purchase the FS728TP switch second hand? If yes, then I advise you to get a replacement from the seller where you have bought the FS728TP switch.
If ever you are the first owner of the FS728TP switch, you may either open an online case with NETGEAR Support or get a replacement from the seller where you have bought it.
DaneA
