CSLLC
Feb 05, 2017Aspirant
FS728TP continuos reboot loop
Ok, I literally just received this off Amazon about 1 hour ago. Out of the box I connect to the servers data port, config and up and going. No issues. I am poking around with the Smart Control s...
- Feb 06, 2017
DaneA,
I followed your suggestions and the results are the same.
At this point I would have to say this is a defective unit.
Do I need to contact NETGEAR and coordinate a exchange with them or with Amazon. This unit is not even 24 hours old.
Thank you in advance,
CSLLC
CSLLC
Feb 06, 2017Aspirant
DaneA,
CSLLC
DaneA
Feb 06, 2017NETGEAR Employee Retired
Did you purchase the FS728TP switch second hand? If yes, then I advise you to get a replacement from the seller where you have bought the FS728TP switch.
If ever you are the first owner of the FS728TP switch, you may either open an online case with NETGEAR Support or get a replacement from the seller where you have bought it.
DaneA
NETGEAR Community Team
- CSLLCFeb 07, 2017Aspirant
Thank you for your help, I received a new switch from Netgear today. Two questions if I may.
1. Is it safe to say to NOT upgrade the firmware as it seems that firmware was what caused this issue.
2. While using the SCC or the web interface, if I choose the device view I am prompted to download the Java plugin and get it here. When yo choose the hyperlink it takes you to Java main page. I did some research on the forum and it seems that your device is looking for Java SE. Is that accurate? If so what version of Java works best? It seems that other users have had issues with anything over Java SE 7.
I look forward to your response.
CSLLC
- DaneAFeb 12, 2017NETGEAR Employee Retired
Let us know if you have further questions.
Otherwise, if ever your concern has been addressed, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- DaneAFeb 08, 2017NETGEAR Employee Retired
I'm glad that NETGEAR provided you with a new switch. :) Here are my answers to your questions:
1. For me, its ok not to update the firmware of the switch as long as the switch functions as it should. However, I would still consider upgrading the firmware because newer firmware versions includes bug fixes more specifically about security vulnerability. By the way, I've checked that you have an FS728TPv2. So if you decide to update the firmware, I advise you to do it via a wired connection by connecting a PC directly to a LAN port of the switch. The FS728TPv2 latest firmware is v5.0.2.45 and you can download it here.
2. About Java, there are several posts wherein the fix is to use Java 7. Some posts indicates Java 7 update 80 while some posts mentioned to use Java 7 with Internet Explorer. Let me share a post which confirms that using Java 7 works with Device View on NETGEAR Smart Switches:
DaneA
