Bullfrog528
May 22, 2019Initiate
FS728TPv2 POE - enable/disable POE for a port using SNMP
Hi Having a similar issue as the original poster of this thread here - https://community.netgear.com/t5/Smart-Plus-Click-Switches/FS728TPv2-MIB-files-Enable-disable-POE-admin-mode-via-NMS300/m-p/150...
- May 23, 2019
Hi Bullfrog528,
Welcome to the community! :)
You can download the FS728TPv2 MIBs on this link. The link will expire within 2-3 days.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
May 23, 2019NETGEAR Employee Retired
Hi Bullfrog528,
DaneA
- Bullfrog528May 24, 2019Initiate
Hi
Thanks so much - it took a while to figure out what I needed from what you made available but i have now managed to do what I needed to. Thanks so much.
The command I used to disable POE/Admin on port 7
/bin/snmpset -t 10 -v 2c -c private 192.168.1.1 1.3.6.1.4.1.4526.11.16.1.1.1.3.1.7 i 2
to re-enable I used
/bin/snmpset -t 10 -v 2c -c private 192.168.1.1 1.3.6.1.4.1.4526.11.16.1.1.1.3.1.7 i 1
If it's not acceptable to show the above info , then please delete post.
Thanks
Jeremy (Bullfrog528)
