Bullfrog528's avatar
Bullfrog528
Initiate
May 22, 2019
FS728TPv2 POE - enable/disable POE for a port using SNMP
Hi Having a similar issue as the original poster of this thread here - https://community.netgear.com/t5/Smart-Plus-Click-Switches/FS728TPv2-MIB-files-Enable-disable-POE-admin-mode-via-NMS300/m-p/150...
  • DaneA's avatar
    May 23, 2019
    Hi Bullfrog528,
    Welcome to the community! :)
    You can download the FS728TPv2 MIBs on this link.  The link will expire within 2-3 days.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
