Picobot
Jul 20, 2022Aspirant
GC110: How to completely block IGMP packets on one physical port or one specific IP address ?
Hello everyone, as the topic says, I am looking for a solution that completely blocks all incoming and outgoing IGMP packets on one physical port of the switch or one specific IP address. The reas...
- Jul 22, 2022
Here is the feedback:
After studying the manual of the GC110 a bit more intensively, the solution was much easier than I had first thought.
Step 1: Create an ACL-Name, in this case "block-igmp"
Step 2: For this ACL, create an IP extended rule with sequence number 1, which blocks all IGMP traffic from the source IP of the o2 access point
Step 3: For the same ACL, create a second IP extended rule with sequence number 2, which allows all other traffic ( match every = true )
This second rule is mandatory, because the switch by default will drop all packets which do not match any of the rules.
Step 4: Bind this ACL to the physical port where the o2 access point is connected.
Now the "IGMPv2 membership querys" which are sent from the o2 AP for some obscure reason can't enter the rest of the LAN anymore and the "Magenta TV" receivers in the LAN are working without any problems.
Until next time, Picobot
