DDT3
Sep 25, 2022Aspirant
GC110P: Insight keeps re-enabling port mirroring
To analyze an issue on my network I ran Wireshark on my PC and switched on port mirroring from a port to the port that PC is connected on. After that, I switched off port mirroring again. In the past...
- Sep 27, 2022
DDT3,
Kindly check and make sure that on both the Insight Portal and Insight App, the Port Mirroring is disabled. If you have already confirmed that Port Mirroring is already disabled on both Insight Portal and Insight App but still it enables on its own, I suggest you to open an online support ticket with the NETGEAR Support Team here at anytime. The NETGEAR Support Team should not deny you with technical assistance since you are an existing NETGEAR Insight subscriber.
DaneA
NETGEAR Community Team
DaneA
Sep 26, 2022NETGEAR Employee Retired
DDT3,
Welcome to the community! 🙂
What NETGEAR Insight subscription do you have?
What is the current firmware version of your GC110P?
Are you the only one who has the credentials to login to the NETGEAR Insight Portal (or Insight App) that can access the settings such as Port Mirroring?
DaneA
DDT3
Sep 27, 2022Aspirant
Hello DaneA,
Thanks for your reply!
It is an Insight Premium Subscription.
Firmware version is: 1.0.5.35
And I (assume I) am indeed the only one with access. Next tot that two-Step-Verification has been switched on for quite some time.
Cheers,
Dries
- DaneASep 27, 2022NETGEAR Employee Retired
DDT3,
DaneA
- DDT3Oct 10, 2022Aspirant
I have done a check on both the app and the web portal (and switched mirroring off on both) used it for a while and problem has not popped up again. Thanks!
