EdgarZe
Nov 03, 2021Tutor
GC110P stuck at "Waiting for first connection"
After relocating, the GC110P is visible in the Insight app but not connecting. It has been waiting for 'first connection' for over a day now. Rebooting, resetting, removing device from account... Noth...
EdgarZe
Nov 09, 2021Tutor
Only thing I haven't tried yet is taking the switch put of my MyNetgear profile. No clue how to do that. So help is requested.
After that I will try to register a new. So far, after removing from insight and factory default it still says that the device is registered with another account... Strange, because it was bought new and previously registered by myself in Insight...
I am clueless...
I am clueless...
schumaku
Nov 09, 2021Guru - Experienced User
There is no mandatory relation requirement between the product registration and the Insight profile, except that adding to Insight would register it to that very same account in case it isn't registered yet.
Is there some security blocking connections towards to the Internet, like some DNS filtering active being on your router, the ISP, or a 3rd party service?
For a test, can you temporarily configure your router to use e.g. the Google and/or Cloudflare DNS IPs like 8.8.8.8 resp. 1.1.1.1, at least these addresses should be assigned by the DHCP server to the clients?
