KadenJessop's avatar
KadenJessop
Netgear 6700AX AX1800 stuck at "Please wait a moment"
I have tried logging into my router and it's stuck at "Please wait a moment". Cannot click on any links in the interface. Router version is V1.0.13.128 which is currently the latest.
What are the solutions to fix this?
  • Sorry to waste your time. I re-started the router and now i was able to login fully.
    Start off with additional information.
    Are you using a real computer or a mobile device?  What operating system?
    Are you connected to the router via an Ethernet cable or Wi-Fi?
    Are you  using an application or a web browser?  Which version?
    If a web browser, what address are your using?
    • KadenJessop's avatar
      KadenJessop
      Using a PC on windows 10, via Ethernet.
      Used chrome, Brave, Microsoft Edge, happens the same.
      Address i used the default 192.168.1.1 then tried routerlogin.net, same thing happens.
      • michaelkenward's avatar
        michaelkenward
        And "the modem/gateway/ONT between the router and the outside world" is?
        Did this just start happening? Or is it a new installation?
    michaelkenward
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    The "environment" bit could include details of how you get on to the Internet, the modem/gateway/ONT between the router and the outside world..
