darrencole
Aug 09, 2022Aspirant
GC728XP Cannot Get DHCP or VLANs to Work
Hi all, I have two of these GC728XP switches (Firmware 1.0.5.35) that were just being used as basic switches for VOIP phones without any configuration! My setup is Comcast Xfinity modem then ...
DaneA
Aug 11, 2022NETGEAR Employee Retired
From the network diagram you have attached, it seems that your modem is a modem-router combo. About your goal to have the devices connected to VLAN 106 to have internet access, VLAN 106 needs to have its own DHCP server. Is your modem-router VLAN capable wherein it has the option to create another DHCP server for VLANs?
As reference guide, kindly check this old article below that shows how VLANs are configured on both firewall router and a NETGEAR Smart Switch (like the GC728XP) that are directly connected to each other:
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
darrencole
Aug 11, 2022Aspirant
Thank you again DaneA! I setup a network identical to the one in your 'VLAN Routing on Smart Switches' guide.
It's a crappy modem-combo that has a DHCP server but that isn't an issue - static IP addresses are fine. One of the steps in the guide is to create a default route on the switch to 192.168.1.1. After doing this I get the alert "The route will not take effect until a routing interface belonging to the same subnet as the next hop is created and activated". Problem is there is no router to do that.
I have added a SonicWall TZ300 Firewall between the switch and the internet which does DHCP and can have static routes so I should be able to set the static route there?
Daz
