haef
Sep 10, 2018Aspirant
GS105E: cannot factory reset, update, or log in
I have a Prosafe Plus GS105E switch. firmware 1.02.04
It's been sitting on the shelf for a couple of months. I got it out to use it, and I cannot access it to configure it. The switch discov...
- Sep 19, 2018
What about using the ProSafe Plus Configuration utility (permitting you have a Windows system at hand) for discovery, then for access/factory reset/firmware update?
haef
Sep 18, 2018Aspirant
I know what address it has. I can see it via a variety of methods such as the NG PS tool as well as an ARP lookup. It's right there at the address it picked up via DHCP but it will not load in any web browser I've tried. Firefox, IE, Chrome, Safari. It looks like it is going to, but then stalls.
I did register it, but only recently. Unfortunately I don't have the receipt anymore which appears to be important for the lifetime warranty.
schumaku
Sep 19, 2018Guru - Experienced User
- haefSep 19, 2018Aspirant
Thanks for the suggestion, but I tried that too. The Windows tool could see the switch but wouldn't allow resetting and so forth.
The whole thing is sort of moot now as I gave the switch to a local techie charity to play with. There's only so much messing with a $50 switch I'm going to do.
