anavo's avatar
anavo
Follower
Sep 08, 2017
gs105Ev2 connected on LiFePo4 up to 14V, max. voltage?
Is there any overvoltage protection on gs105Ev2?
Datasheet says only 12 V @ 1,0 A
  • Hi Anavo,
    Our switch products are designed to be used with our current PSU, unfortunately using other Power Supplies could damage the product so we don't recommend to use a non-NETGEAR PSU.
    If you are looking for a  DC powered I would recommend to check our PoE powered switches like GS108T or GS105PE that they can be powered using a PoE injector
    Xavier Lleixa
    NETGEAR CBU PLM
    Regards
1 Reply
  • XavierLL's avatar
    XavierLL
    NETGEAR Employee Retired
    Hi Anavo,
    Xavier Lleixa
    NETGEAR CBU PLM
    Regards
ProSupport for Business
