Chris-L
Aug 07, 2016Follower
GS105eV2 Firmware Update 1.4.0.9
Hi,
can anyone help me what the new feature "Added the option to enable/disable Plus Utility Management under Web GUI." means.
If i get when i enable this option it won't be possible to sue the "Plus Utility" Tool for configuring the switch.
If i do so are there any improvements ?
Maybe anyone has some information would be nice if you share.
Regards
Chris
Hi Chris-L,
Welcome to the community! :)
For me, it means that when you enable this feature then you will be able to manage the GS105Ev2 switch via the ProSAFE Plus Configuration Utility. Otherwise, if you disable it, then you can only manage the GS105Ev2 via its web-GUI.
I believe the improvements are mentioned on the Bug Fixes. Check it here.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Chris-L,
DaneA
Hi Chris-L,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
