Stev3D
Jan 03, 2019Luminary
GS105Ev2 Firmware Update will not go into Bootloader Upgrade mode
I noticed that the device's firmware was still at v1.4.0.5 and the Bootloader was (not surprisingly) v1.4.0.5-VB , and went to the product's Downloads list, saw that v1.6.0.3 was the current firmware...
- Mar 02, 2019
You are not seeing the bootloader update page because firmware knows you already have the latest bootloader. Latest bootloader version is 1.4.0.5
JohnC_V
Jan 04, 2019NETGEAR Employee Retired
Hi Stev3D,
You may try to go directly in the bootloader page. Please try this http://x.x.x.x/loader_upg.htm (x.x.x.x represents your GS105E’s IP address).
Stev3D
Jan 05, 2019Luminary
Thank you, JohnCarloV , for the suggestion. I wish it had worked.
I tried the URL you provided (obviously replacing "X.X.X." with the approriate IPv4 address) and after authenticating, I was brought to the normal "Switch Information" page. I postulated that the authentication step is hard-coded to coming to that default page -- so I tried to reach the the "/loader_upg.htm" page again multiple ways, including pasting that URL into a new tab, and simply replacing "login.cgi" text in the address bar with "loader_upg.htm" -- and in every case, I got a completely blank page.
I also tried it using a completely different Web browser (one stripped-down with no add-ons, blocking, etc -- which I use for diagnostics), and the results were identical: A completely blank page.
I have tried software reboots, and power-cycling -- no change.
Do you have any other suggestions?
Thank you.
