Stev3D
Jan 03, 2019Luminary
GS105Ev2 Firmware Update will not go into Bootloader Upgrade mode
I noticed that the device's firmware was still at v1.4.0.5 and the Bootloader was (not surprisingly) v1.4.0.5-VB , and went to the product's Downloads list, saw that v1.6.0.3 was the current firmware...
- Mar 02, 2019
You are not seeing the bootloader update page because firmware knows you already have the latest bootloader. Latest bootloader version is 1.4.0.5
JohnC_V
Jan 07, 2019NETGEAR Employee Retired
May you be able to try updating the firmware using the Prosafe Plus Utility? It seems that it did worked on this thread.
- Stev3DJan 07, 2019LuminaryJohnCarloV , I tried that. Unfortunately, ProSafe is a Windows-only utility, and the only Windows I have is a seldom-used VM which NATs through the host OS. Becasue of the NATing, ProSafe can't find the switch. When I attempt to connect the VM directly (bridge through the host OS, getting a valid network configuration via DHCP), I lose all network connectivity on the VM. I'm not sure why -- I tried everythign I could think of (can't even ping on the local LAN).It would sure be nice if the platofrm-agnostic Web interface worked correctly. Any other suggestions?
- Peter-K2Mar 02, 2019Guide
- Stev3DMar 24, 2019Luminary
Peter-K2 , thank you. It is embarassing that it was something so trivial. I was unable to find any clar documentation or indication to that effect
