Stev3D
Jan 03, 2019Luminary
GS105Ev2 Firmware Update will not go into Bootloader Upgrade mode
I noticed that the device's firmware was still at v1.4.0.5 and the Bootloader was (not surprisingly) v1.4.0.5-VB , and went to the product's Downloads list, saw that v1.6.0.3 was the current firmware...
- Mar 02, 2019
You are not seeing the bootloader update page because firmware knows you already have the latest bootloader. Latest bootloader version is 1.4.0.5
Stev3D
Jan 05, 2019Luminary
Thank you, JohnCarloV , for the suggestion. I wish it had worked.
I tried the URL you provided (obviously replacing "X.X.X." with the approriate IPv4 address) and after authenticating, I was brought to the normal "Switch Information" page. I postulated that the authentication step is hard-coded to coming to that default page -- so I tried to reach the the "/loader_upg.htm" page again multiple ways, including pasting that URL into a new tab, and simply replacing "login.cgi" text in the address bar with "loader_upg.htm" -- and in every case, I got a completely blank page.
I also tried it using a completely different Web browser (one stripped-down with no add-ons, blocking, etc -- which I use for diagnostics), and the results were identical: A completely blank page.
I have tried software reboots, and power-cycling -- no change.
Do you have any other suggestions?
Thank you.
